Subject: News&Articles Module
gabrieleseven
07 Oct 2008 9:45 AM
Hello, I've created a Portal for news and info about the world of music. I need a module that allow me to manage news for category (like the Articles Page). Could you suggest me a module for this?
08 Oct 2008 7:16 AM
Ventrian News articles is a good one. Also, I'm really fond of Engage's Publish module. It has lots of great features.
Forums > DotNetNuke® > Modules - What's needed? > News&Articles Module
