Subject: Page Templates Not Showing
ktm200
30 Mar 2008 4:02 PM
Hi I exported page templates, have done all the obvious stuff.  Made sure they were in the right subdirectories, XML is good... etc...
But they don't show up on the Template drop down in the import area.  Or on the page template area of the Add Page area.  Even the Default Page does not show up and it is there.  The only thing that shows up is "None Specified"
Any ideas...
Thanks I am at wits end
31 Mar 2008 8:33 PM
If you haven't done so already, you might want to review How to create Page Templates in DotNetNuke
ktm200
01 Apr 2008 8:02 AM
I did view those tutorials. Made the page templates. Put them in the correct directories. But the Combo Box on the import page and add pages area does not populate with them. I went ahead and loosened security up on the server so everyone had all rights.
Not even the default template shows up.
Any ideas?
01 Apr 2008 8:35 AM
Hmmm ... unfortunately no. Anyone else?
02 Apr 2008 9:33 AM
I'm not sure either, if something is missing, I usually go to host menu / host settings - restart application
drosenstark
22 Apr 2008 6:08 PM
I have the exact same problem. But you can simplify it even further. I export a page in the Root of the portal, and then I try to import the page and NO pages are showing.
I have another DNN installation which is almost identical in which I can export and import pages with no problem.
If I solve it, I'll let you know. Might be a 4.082 problem, since your post is so recent and I just started having this problem (though I never tried this feature before, so who knows?).
drosenstark
22 Apr 2008 6:34 PM
Hi. I'm quite sure it's a 4.082 problem. On my 4.081 installation it works. Can anyone who has a 4.082 installation import pages? Thanks in advance to anyone who tries this.
22 Apr 2008 7:41 PM
I did see a couple of reports over on the DotNetNuke forums with other people suggesting that there is a bug in 4.8.1 and/or 4.8.2. Let's hope it will be fixed soon.
ktm200
23 Apr 2008 9:02 AM
After spending about 16 hours on this problem...it is a critical funtionality of our application...The guys at PowerDnn...there a pretty smart bunch...did confirm it is a bug in 4.082....back to 4.7 we reverted...
ps it only happens on new portals, not ones that had been upgraded...
rmjcsltd
07 May 2008 4:56 PM
For anyone else suffering from this problem, here's the solution I found (thanks to someone else) that worked for me.
In Host Settings, add 'template' (without the quotes) to the 'File Upload Extensions: ' value in the 'Other Settings' section. Save the change. Then in Host File Manager re-synchronise files with the recursive option. If you don't have Host access then you'll need to get your Host to do this.
Job done - templates now appear where expected.
Regards, Rhys
07 May 2008 8:53 PM
Thanks for the tip!
TOOL
26 May 2008 6:34 AM
Thanks a lot for the tip rmjcsltd.
Now I can see the template files on the dropdown menu on page settings!
Nice one dude!!!
vjcapron
24 Jun 2008 8:30 PM
I had to clear the cache first before the steps detailed above would work for me.  My site is using Moderate Caching.
Forums > DotNetNuke® > DotNetNuke® Questions > Page Templates Not Showing
Have a look at the tabs table
page publish date by dnnwebuser
HiI would like to know the table to get page information(page name,publish date and time).Could you ...
RE: Keep Testing Skins by leesykes
For the downloads from DNN Creative you should not have to rename.When you upload the skin zip it sh...
RE: Old style skinning by leesykes
If you are using the logo skin object you should not get any repeat problems. I can't really tell fr...
Have you tried to re-apply the permissions for Network Service across the entire installation files?...
I have not added line breaks in before like that, most of the time I would setup a menu to just wrap...
on the part 6 page, amongst the video links is a link named:Vortex Music Skin Stage OneThese are the...
RE: Query regarding Site Log by leesykes
Once you start enabling logs, also make sure you schedule to delete the old logs:Site logs, Event lo...
RE: How to speed DNN by vdelisi
It could be related to the use uf resx file to localize the portal. I'm thinking about that becau...
Keep Testing Skins by ollep
Thanks for your reply Yesterday Lee. I will do a new upload and see if I can get the template worki...
RE: 3Essentials Hosting by nlssolutions
I wanted to post an update about 3Essentials. I had a few struggles with speed and some modules tim...
RE: Old style skinning by adrian_scott_day
Lee, The Logo skin object doesn't seem to have a property for setting a CSS Class. I'm using the sk...
RE: redirecting registered user to a specific page by jncraig
Go to the User Settings page under Admin. On that page, pull down the menu and click on User Settin...
RE: Building a website with DNN by jncraig
At the bottom of the page you will see the links for the various parts of the tutorial.  If you clic...
RE: How do i change the global font of the site by balousta
Thank you for your advice, I have seen the  tutorials long time ago, but I'm not good in css in gene...
Lee,Thanks for your suggestion about checking event log.  Here's what I did...First, in site Admin>>...
redirecting registered user to a specific page by saintX
Hello,Is it possible to redirect a user after registration to a specific page? If yes, please tell m...
Solpartmenu and line breacks by saintX
Hello,I have to make linebreacks on Solpartmenu, okay I do it using . Bur the secound line appears o...
Hi Joe,   Thanks for your reply. I have looked at those links and I can't seem to find the files f...
RE: Query regarding Site Log by puuri
Joe is exactly right with his suggested fix for your problem. I am very new with DotNetNuke and ran...
