Subject: how i can logout external web from dnn
meenu
20 Mar 2008 2:48 AM
hi all
advance thanks to all.
i have 2 requirements..can anybody help me???
let me describe my problem.i am using dnn0408, Visual studio 2005 ->asp.net web application ->based on VB language.
in my dnn website, i created my own module.
in that module i have a link button.when i click this link button my another website(not dnn web)  is coming. my coding is as follows for this purpose.
ClientScript.RegisterClientScriptBlock(Me.GetType(), "popup", "window.open('http://externalwebname','','scrollbars=yes,menubar=no,height=100%,width=100%,resizable=yes,toolbar=no,location=no,status=no')", True)
my requirements are
1.i want to close my externalweb when i logout from dnnweb
2.i want external web height and width as full screen mode
regards
Forums > DotNetNuke® > DotNetNuke® Questions > how i can logout external web from dnn
WOW GOLD by wowgolds987
RE: Pop up window by yerann
RE: Events calendar by mjbieg
