Subject: Edit mode in Internet Explorer
jfitzgerald
18 Mar 2008 5:50 AM
Morning..
Always the internet explorer make my like worst.. i'm having a problem, and i already tried a lot of different things, and test, and test.. and nothing..
Well, the problem is that in the edit mode, after you login in the internet explorer they show my panes one under the other, it isnt showing in the real structure that i had created.. i had a look in the width of the panes, and i'm using pixels.. not percents.. i tryed put widths inside the containers, but the problem still happen.. more some informations: it's a pure css skin.. and HERE is the url.. if someone could give me a help, i'm really frustrated with this..
Thanks a lot..
Jorge
20 Mar 2008 5:47 AM
I'm not sure what the problem will be, it's hard to tell when we can't see the problem in edit mode.
one thing I would check is floats and clears are correctly setup
another is to look at your container.css
- using the web developer toolbar I can see 3 container.css files in use and they all seem to repeat elements of the CSS - including the body, the body should really only be specified in the skin.CSS
Also, if you have
.fassetnotitletransparent
    margin:0px;
    padding:0px;
in container 1.css and
.fassetnotitletransparent a
 font-size:8pt;
specified in container 2.css
This CSS from container 2 will also be applied to container 1 as the CSS from container2 is read second and therefore overrides the settings with the SAME class from previous CSS files. - I would double check the container.css files as you could probably strip out quite a lot of code out of those CSS files.
- I like the design of the skin though, cheers,
Forums > DotNetNuke® > DotNetNuke® Questions > Edit mode in Internet Explorer
Web.config Error by derpir
Yahoo Answers by cdtguru
RE: Videos by clippy
skinning trouble by derpir
RE: Template Issue by jncraig
