Subject: Transfer to IIS Server
thtang
27 Dec 2006 11:40 AM
I have a dnn website stored in the folder A. I would like to ask if it's ok to copy all the files in folder A to IIS server? or i also need to install dotnetnuke in the server ?
Thank you.
Forums > DotNetNuke® > DotNetNuke® Questions > Transfer to IIS Server
RE: Database error by derpir
