You need to
Register
for free and
Forums
Search Forum
Advanced Search
Topics
Posts
Unanswered
Active Topics
Forums
DotNetNuke®
DotNetNuke® Questions
DotNetNuke Roles assignments
Last Post 07/28/2009 11:45 AM by
Backy
. 4 Replies.
Oldest First
Most Recent First
Prev
Next
Author
Messages
Backy
07/28/2009 10:47 AM
Is it possible to implement roles dynamically for hiearchical access like parents and child relationships? When user is logged in, I want to compare that user with some conditions(Business Logics and some other data from database) and if those conditions met, i want to allow that user to view specific module otherwise not. Does DotNetNuke allow this kind of flexibility in security and roles assignments?
DNN MVP
07/28/2009 10:56 AM
Yes, it's possible to do this, but not quite out of the box.
Check and see if Dynamic Login from Data Springs will let you do it.
If not, then it's a fairly straightforward process to create a custom "authentication provider" to replace the existing DNN Authentication Provider. I did this over the weekend for a client site that requires a user to be optionally assigned/not assigned to a security role at login. It would be quite easy to extend that to more complicated business rules.
It turns out that the authentication provider is fairly simple -- a login page and some codebehind that is invoked when the Login button gets clicked. I added code right at the end of that event handler to check the user's credentials, information from a database, and add or remove the user from the role. I used a recent blog post written by Joe Brinkman as the inspiration/guide for this approach. It took only a couple of hours, and most of that was me not paying attention as I wrote code!
I could guide you through this ... assuming that you have some .NET programming experience. If not, you'll need someone to help. But ... it really is quite easy.
Joe Craig,
Patapsco Research Group
Complete DNN Support
Backy
07/28/2009 11:15 AM
Hi Joe, Thank you so much for your quick reply. I am new to DotNetNuke, but yes I have experience in .NET Programming. Plese guide me about this in more details.
DNN MVP
07/28/2009 11:22 AM
Most important ... which version of DotNetNuke are you using?
I'd also suggest these books:
DotNetNuke Professional
(There is a 4 and a 5, for the different versions. Having both, as they were written by different people, isn't a bad idea.)
DotNetNuke Module Programming by Mitchel Sellers
The new book by Chris Hammond and Patrick Renner
is very basic, but might be useful to a newcomer.
Also, find Joe Brinkman's blog (The Accidental Geek) and look at the recent entry about authentication. If you are using DotNetNuke 5, you can download his code and start from there. If you are using DotNetNuke 4, I can send you a copy of my code. You can email me at jncraig at gmail dot com and I'll reply. My code is slightly different from Joe's, mainly because of differences in going from V4 to V5.
Joe Craig,
Backy
07/28/2009 11:45 AM
I am using version 4.9. I will read these books and will send you an email. Thank you so much. I appreciate it.
Special Bonuses
--Subscriber Bonuses
--Readers Offers
Users Lounge
--Announcements
--DNN Creative Articles
--Everything Else
--Membership
--Site Review Please!
--Testimonials
--Podcasts
DotNetNuke®
--DotNetNuke® Questions
--Modules
--Modules - What's needed?
--Quick Tips
Hosting
Skinning Toolkit
--Skinning Toolkit
UK DotNetNuke User Group
Forums
DotNetNuke®
Can you Run Xcode in Linux?
by Aman Singh
by Aman Singh
by Ryan
by DNN User
by DNN User
by DNN User
by Melanie Weaver
Events Module for DNN V5?
by Tugboat
"Ghost" TabID Number?
by Tugboat
RE: DNN Load Testing
by ayman sharkawy
Publish All Pages
by NSUOK
by Donald
by Donald
RE: Document Collaboration
by Nick Davern
by Donald
by Jakir HM
by peter
