Subject: [Server Error]This error can be caused by a virtual directory not being configured as an application in IIS.
bukk
18 Aug 2006 11:44 AM
I have asigned aspnet control rights to the dnn directory. DB and web.config have been configurated.
But the ERROR still there:
Server Error in '/dir' Application.
Configuration Error
Description: An error occurred during the processing of a configuration file required to service this request. Please review the specific error details below and modify your configuration file appropriately.
Parser Error Message: It is an error to use a section registered as allowDefinition='MachineToApplication' beyond application level.  This error can be caused by a virtual directory not being configured as an application in IIS.
Source Error:
Line 45:   </system.codedom>
Line 46:   <system.web>
Line 47:     <machineKey
Line 48:       validationKey="F9D1A2D3E1D3E2F7B3D9F90FF3965ABDAC304902"
Line 49:       decryptionKey="F9D1A2D3E1D3E2F7B3D9F90FF3965ABDAC304902F8D923AC"
Source File: D:\dir\dnn\web.config    Line: 47
Show Additional Configuration Errors:
It is an error to use a section registered as allowDefinition='MachineToApplication' beyond application level.  This error can be caused by a virtual directory not being configured as an application in IIS. (D:\dir\dnn\web.config line 93)
It is an error to use a section registered as allowDefinition='MachineToApplication' beyond application level.  This error can be caused by a virtual directory not being configured as an application in IIS. (D:\dir\dnn\web.config line 154)
It is an error to use a section registered as allowDefinition='MachineToApplication' beyond application level.  This error can be caused by a virtual directory not being configured as an application in IIS. (D:\dir\dnn\web.config line 162)
Version Information: Microsoft .NET Framework Version:2.0.50727.42; ASP.NET Version:2.0.50727.42
I need help, thanx
18 Aug 2006 5:44 PM
Andrew Hock, a module developer - site: www.fingerfuel.com is currently putting together an installation doc for the next issue. - I have a rough version which he has given me permission to send.
If you email me at: lee at dnncreative.com
I will send it across to you which may help you to get started configuring DNN.
bukk
19 Aug 2006 10:23 AM
Thank you!
I have Emailed you
21 Aug 2006 4:43 AM
I've sent it across, thanks
sattysir
20 May 2008 8:53 AM
I got the same error "This error can be caused by a virtual directory not being configured as an application in IIS." when installing to DNN site.
I need help.
Satyendra
Nuke Master I
Nuke Master I
20 May 2008 9:08 AM
Something is wrong either with your IIS installation, or the way you created the IIS website.  Take a look at these for some help:
You might find a step that you've missed.
Which version of DotNetNuke?  What operating system?  Local or hosted?
Forums > DotNetNuke® > DotNetNuke® Questions > [Server Error]This error can be caused by a virtual directory not being configured as an application in IIS.
RE: PowerDNN by jazzylily
RE: PowerDNN by DavidWSnow
RE: PowerDNN by mgordon
Great!
RE: PowerDNN by MobileNow
