Subject: open customized user control on new window
parag
21 Dec 2005 3:11 AM
I want to open new windown in DNN 3.0 with with cutomized user control...
how can i do this please tell me.....
parag
21 Dec 2005 3:23 AM
Morning!
Could you go into a few more details please Parag as it sounds just like the previous question for opening a module in a new window.
What do you mean by customized user control? If you can give me the full details I will be able to give you an answer exactly to your needs rather than a general answer.
parag
21 Dec 2005 4:10 AM
Hello
i have created one module for e.g. say request when i want to add customer in to that , i just click on one link say list after clicking
that customer list should be open on new window haveing hyperlink on all customer name list so that i just  click on customer name that would be come on previous page.....
parag
21 Dec 2005 5:48 AM
If I understand you correctly, you have a module where you want to click on a link which will then open a new window with further details.
In a previous module that I've created, I had a datagrid which included a view link - this link opened a separate window. To do this I used this code:
Basically this opens up a new control page that I created. - If you've created a module settings page, this is the same sort of thing, except we are opening it using a link rather than the module settings menu and it opens in a new window. (Doing it in this way makes the module use the skin of the admin section of your site as it is seen as an admin control)
Forums > DotNetNuke® > DotNetNuke® Questions > open customized user control on new window
