Subject: Cross-browser support
coder247
12 Aug 2008 3:47 AM
Hi all,
  We are creating a website and we would like to incorporate cross-browser functionality. I found that, the controls created by DNN works perfectly fine for Mozilla as well as IE. But the custom controls I've created works fine on IE but goes haphazard on Mozilla. Textboxes and buttons go completely out of order. Please suggest some tips on how to approach this problem.
Any videos on the same would be of great help.
Sridhar.
13 Aug 2008 6:33 AM
it all depends what you are working on, usually browser compatibility is relatively straightforward.  You may find this tutorial useful however for troubleshooting any problems that you are having:
Forums > DotNetNuke® > DotNetNuke® Questions > Cross-browser support
