Subject: Query regarding error
kaustav_kar
30 Jul 2008 2:08 AM
I want to know that what is the cause of the following error?
Server Application Unavailable
The web application you are attempting to access on this web server is currently unavailable.  Please hit the "Refresh" button in your web browser to retry your request.
Administrator Note: An error message detailing the cause of this specific request failure can be found in the application event log of the web server. Please review this log entry to discover what caused this error to occur.
30 Jul 2008 7:38 AM
Can you provide any more details? Is this a new site? Has this started happening in an old site? If so, what did you change?
30 Jul 2008 7:41 AM
You'll need to determine if this is a DotNetNuke issue, and ASP.NET issue, or an IIS issue.
To check out IIS, but a file named index.htm in the web directory. Then browse to the site. If you see that index.htm is being served, then IIS is ok.
Next, but an file named app_offline.htm in that directory (after removing index.htm). Is that file served?
If both of those files are served, then you have something wrong with DotNetNuke. More details will help understand what it is.
Forums > DotNetNuke® > DotNetNuke® Questions > Query regarding error
