Subject: Using the DNN Document Module
billkidwell
28 Jul 2008 6:04 PM
How does one use the DNNCreative search function to figure out how to use the Document module. I am told that using a word doc and copy/paste uses too much resource, so I should use a pdf format, but I can not figure out how to the the pdf format onto a page and I was todl to sue the docuemtn module, but that is absolutley unclear to me about how to "upload" the pdf to the module. When I try to use DNNCreative search it never brings me to a subject that appears even remotely realted to my question unless I want the 1st grade primer on DNN Page management??
28 Jul 2008 6:51 PM
There are two separate search tools for this site.  One, just below the menu bar, searches the site and the other searches the forums.
When I'm looking for a tutorial, I'll just go to the Tutorials page and use my browser's search to find a word or phrase.  In this case:
Documents Module.
05 Aug 2008 5:31 AM
yes, unfortunately the built-in DotNetNuke search is not very useful. The DNN creative site has grown so large that the DotNetNuke search cannot index all of the content.
The best place to search for a tutorial is on the main tutorials page, or you can also search with this tool here
Forums > DotNetNuke® > DotNetNuke® Questions > Using the DNN Document Module
