Subject: Portals/Child portals - module integration
jmccormick
21 Jul 2008 7:03 AM
How do we share a portal and all of its attributes from parent to child portals? Anyone else doing this?
JMc
21 Jul 2008 8:29 AM
I believe that there are some third-party tools out there to share accounts across portals within an installation.
For sharing content, on of the better suggestions I've seen is to create RSS feeds on the parent, and show them on the other sites. There may be ways of sharing pages, but I can't give you a reference, other than to suggest Googling.
Forums > DotNetNuke® > DotNetNuke® Questions > Portals/Child portals - module integration
