Subject: User Registration
gulfaraz
16 Jul 2008 5:46 AM
I had inherited a DNN 3.2 Project with a number of custom modules and a number of portals already created. I'm trying to write an sql query that will return me a list of all users and the portal they registered on. I've found the users table (dnn_users) and the portal table (dnn_portals_ but I can find any primary keys that link the users to specific portals. Does such a thing exist?
Gul
17 Jul 2008 8:41 AM
Try the UserPortals table.
