Subject: Editing styles of hyperlinks
adrian_scott_day
15 Jul 2008 11:26 PM
Lee,
I was wondering where I would look to try and edit the style on the hyperlinks that are displayed for a links module in list view rather than drop down view.
Essentially I just want to change the font that is used, the font color and the size.
Kind regards,
Adrian Scott-Day
17 Jul 2008 8:47 AM
If you become familiar with the skinning tutorials here, many of your questions will get answered.  But, I'd recommend these tutorials, too:
And, to summarize, you want to find the overall IDfor the module, then you want to add specific styles for the links in that class into your skin.css file.  One way to find the IDis to look at the page source, find the links module, and then identify the ID.  For example, you might see:
< !-- Start_Module_737 -- >< div id="dnn_ctr737_ModuleContent" >
The ID for this module is dnn_ctr737_ModuleContent.
17 Jul 2008 11:10 AM
This tutorial will be helpful for identifying IDS etc.
Forums > DotNetNuke® > DotNetNuke® Questions > Editing styles of hyperlinks
