Subject: Change Default Module Displayed on New Pages
nstump
14 Jul 2008 2:11 PM
How do I change the default Module that is added to every new page I create? I would like to have a different module then text/html show up when I make new pages.
Thanks.
-Alex
14 Jul 2008 8:04 PM
When you create a new page, one of the fields that you enter is the template to use.  You can change how the new page is created by choosing a different page template.  For more information ...
How to create Page Templates in DotNetNuke.
Forums > DotNetNuke® > DotNetNuke® Questions > Change Default Module Displayed on New Pages
