| RE: SolPart Menu Font Color Control by cdees |
| Lee, Is there documentation, or perhaps a tutotial on activating and using Nav menu? Where would I... |
| RE: EasyCGI help? by Dr Joe |
| I found some interesting posts on some other sites that explain some of the challenges I've been exp... |
| RE: Menu's, menu's, and more menu's! by roadshow41 |
| Thanks! I'm still a bit curious about some of the other options, but I think that gives me enough c... |
| RE: Menu's, menu's, and more menu's! by leesykes |
| Hello,Yes that should be possible with snapsis, I have used snapsis CSS with flyout menus on a horiz... |
| I typically end up using a hybrid of a vertical menu and a horizontal menu due to the sheer number o... |
| DotNetNuke SEO (Search Engine Optimization) by leesykes |
| Hello,I regularly get asked for tips on SEO with DotNetNuke, there are several resources available o... |
| Hello,If you are looking for a menu for SEO reasons, any CSS based unordered list menu will be SEO f... |
| Well, I've been trying to steam ahead with the DNN sites I inherited a few months ago. I've found l... |
| RE: EasyCGI help? by derpir |
| Hi Lee
I told them that solution two days ago and still no answer, but thanks for suggesting that s... |
| RE: quick question by derpir |
| Hithanks! yes I understand. I will deal with my skins more tomorrow, maybe some questions will arriv... |
| RE: Restart Application by leesykes |
| It will restart your DotNetNuke installation and reload the application.Clearing cache will clear th... |
| RE: How can i edit any module from front end by leesykes |
| hello,I have just tested this and can see exactly the same as you, I suspect the core team have set ... |
| RE: EasyCGI help? by leesykes |
| You may want to ask them to reset the correct permissions on your DotNetNuke installation files, som... |
| RE: quick question by leesykes |
| Hello,It will be possible to a degree, but it depends on how both of the skins have been built. You ... |
| I'll let you know how it works out. I think I opened up about 6 tickets with them so far. ... |
| Hi Joe
amazing to say the least!
I will change host to PowerDNN as soon as possible, seems to me t... |
| Amazing - I'm going through this exact same thing with EasyCGI! I managed to successfully instal... |
| Running the local host installation after building the application by saintX |
| My localhost installation of DNN was running blameless. After I oppened the application with VWD it ... |
| Hello
Is it possible to buy two skins and combine them? for example put one skins visual attributes... |
| RE: Environment Variables by leesykes |
| Thanks for the info, |
