Subject: how to implement sifr in dotnetnuke
rao_babu24
08 Jul 2008 3:23 AM
how to use sifr technology in dotnetnuke. any one have sample videos on this topics pls help me. I am new to dotnetnuke .
thanks advance
10 Jul 2008 1:45 PM
Incorporating sIFR (Scalable Inman Flash Replacement) with DotNetNuke skins
Forums > DotNetNuke® > DotNetNuke® Questions > how to implement sifr in dotnetnuke
