Subject: autocomplete extender
HSS
29 May 2008 11:58 AM
 I am a beginner in ASP.Net AJAX  , I am using Visual Studio2005 and I am trying to implement AutoComplete with an Access database connection I search for the code which I should put inside the web service and I hardly found this code which is written in VB and deal with access.. but still I don’t know wither this code is correct or not and where I should make changes to appropriate with mine..
  • The web service I call it AutoComplete.
  • The search text box I call it myTextBox.
  • The access database is in C:\Documents and Settings\user\My Documents\Visual Studio 2005\WebSites\AutoComplete\db1.mdb
  • The table which I choose from is recipes.
  • The column I should choose the word from is Name.
The code is:
Imports System.Web
Imports System.Web.Services
Imports System.Web.Services.Protocols
Imports System
Imports System.IO
Imports System.Collections
Imports System.Collections.Generic
Imports System.Threading
Imports System.Xml.Serialization
Imports System.Data
Imports System.Data.SqlClient
Public Class WebService
     Inherits System.Web.Services.WebService
     _
     Public Function GetWordList(ByVal prefixText As String, _
          ByVal count As Integer) As String()
        If autoCompleteWordList Is Nothing Then
            Dim MyArrayList As ArrayList = New ArrayList
            Dim connectionString As String = System.Configuration.ConfigurationManager.ConnectionStrings("medsidConnectionString").ConnectionString.ToString
            Dim dbConnection As System.Data.IDbConnection = New System.Data.OleDb.OleDbConnection(connectionString)
            Dim queryString As String = "SELECT Distinct([Pacientes].Nombre) FROM [Pacientes] WHERE '" & prefixText & "%' ORDER BY Nombre"
            Dim dbCommand As System.Data.IDbCommand = New System.Data.OleDb.OleDbCommand
            dbCommand.CommandText = queryString
            dbCommand.Connection = dbConnection
            dbConnection.Open()
            Dim dataReader As System.Data.IDataReader = dbCommand.ExecuteReader(System.Data.CommandBehavior.CloseConnection)
            While dataReader.Read()
                MyArrayList.Add(dataReader("Nombre"))
            End While
Dim temp As IDataReader() = CType(MyArrayList.ToArray(GetType(IDataReader)), IDataReader())
                temp = MyArrayList.ToArray()
            Array.Sort(temp, New CaseInsensitiveComparer())
            autoCompleteWordList = temp
        End If
        Dim index As Integer = Array.BinarySearch(autoCompleteWordList, _
          prefixText, New CaseInsensitiveComparer())
        If index < 0 Then
            index = Not index
        End If
        Dim matchingCount As Integer
        For matchingCount = 0 To count - 1
            If Not (matchingCount + index) < autoCompleteWordList.Length Then
                Exit For
            End If
            If Not autoCompleteWordList((index _
              + matchingCount)).StartsWith(prefixText, _
              StringComparison.CurrentCultureIgnoreCase) Then
                Exit For
            End If
        Next matchingCount
        Dim returnValue(matchingCount - 1) As String
        If matchingCount > 0 Then
            Array.Copy(autoCompleteWordList, index, returnValue, 0, _
              matchingCount)
        End If
        Return returnValue
    End Function
End Class
Any advise would be helpful, thanks
Forums > DotNetNuke® > DotNetNuke® Questions > autocomplete extender
Glad you sorted it, thanks,
