Subject: Restrict Page Access by Role
giblets
28 May 2008 12:12 PM
Lee,
Is there any way to make pages that are public and viewable when not logged in, be invisible and not on the menu when a user is logged in?
Is there any way to restrict page access by Role/Group?  Are DNN Rights only cumulative?
28 May 2008 10:49 PM
Set the Permissions for the page so that it can be viewed only by "Unauthenticated" users (and administrators). If you login, the page will disappear from the menu, and you won't be able to see it, even if you know the URL.
giblets
29 May 2008 8:51 AM
Posted By jncraig on 28 May 2008 10:49 PM
Thank you Joe!  You've just made my day!
29 May 2008 8:58 AM
They should all be that easy!
Forums > DotNetNuke® > DotNetNuke® Questions > Restrict Page Access by Role
