Subject: Specified Container for a specified group of pages
jfitzgerald
16 Apr 2008 10:30 AM
Hello again..
Now what i would like to know is if i can apply a page container (to always that someone insert a new text html modual in the page comes with that container), if i can apply this for a group of pages, like inside of a parent page.. i know that i can apply page by page, but what i would like is that always that someone create a page inside this parent page, and insert a text/html modual in that new page, it comes with a specified container.. is this possible!?
Thanks a lot,
Jorge Carvalho
16 Apr 2008 7:44 PM
I don't think so, though that would be a great feature. If you want to use a special skin to a group of pages, you'll have to do it one page at a time.
Why not scoot over to the DotNetNuke site and submit that as a feature request.
Forums > DotNetNuke® > DotNetNuke® Questions > Specified Container for a specified group of pages
