Subject: is there any video for email or newlatters
rizwan7705
25 Apr 2008 6:51 PM
hello i m want ot setup email services in dnn. i want to set sending and recieving emails system on dnn and same for newlatters is it possiable can some one help me in it.or is there any video avaliable on dnn creative . plz lee help me out in it thanks
rizwan
26 Apr 2008 3:08 AM
Have a look at:
Forums > Users Lounge > Everything Else > is there any video for email or newlatters
