remove DNN link from bottom of DNNBlue skin
Last Post 2006-05-08 02:26 PM by owen grant. 2 Replies.
owen grantUser is Offline
2006-05-08 05:15 AM
Hi,  I was wondering how to remove the "DotNetNuke® is copyright 2002-2006 by Perpetual Motion Interactive Systems Inc." link from the bottom of the DDNBlue skin.
Is there somewhere i can edit it in the settings logged in as admin or host,  or do i have to edit the skin and re-upload it as per your skinning video tutorial.
Owen
2006-05-08 10:26 AM
Log in as Host, go to the Host Menu / Host Settings
Under Appearance, un-tick "Show Copyright Credits"
2006-05-08 02:26 PM
Excellent thanks :-)
I was stairing straight at it but just could see it. thanks again.
DNN nav issue by imran shaikh
