Best Practices for Modifying a Custom Module
Last Post 2012-02-08 05:35 PM by Joseph Craig. 1 Replies.
Author Messages Not Resolved
schildersUser is Offline
2012-02-08 05:02 PM
Good Morning,
I'm needing to modify a custom built module created by another developer targeted for DNN 5.6.3. I've setup VS 2008 with the DNN Visual Studio module component template. I've tried just adding the existing files from the module package to my solution, and have also tried copying/pasting the code from the modules to my solution. Both approaches yield a number of build errors preventing me from checking my work.
Can anyone provide some best practices on modifying a custom module? What is your procedure to edit the ascx and vb files, debug them and then upload to the portal for testing?
Sid
Joseph CraigUser is Online
2012-02-08 05:35 PM
Start up the development website, then install the module using the package that you have. Then, you should be able to go in and edit the module.
I would start by changing the module's name and namespace so that it will be entirely separate from the starting version. I'd do that and verify that it works with just the changes. Then, use the create package functionality to create a new installable module.
Now, unistall the original package, install the new one (with the changed names), and go from there.
To be really right, you should probably change names of database tables, prefixes for db names and stored procedure names, etc.
RE: Deploying dnn by Sameer
Just sent it.
