Admin menu problem
Last Post 2012-02-12 03:07 PM by alireza arabiyan. 6 Replies.
alireza arabiyanUser is Offline
2012-02-07 04:25 PM
hi
i installed dnn 6 on localhost and move it in my host, all link's , pages and modules are ok,
but only admin menu link's such as /Admin/Extensions.aspx and other's admin submenu show 404 error
please help me to solve this issue
Joseph CraigUser is Online
2012-02-08 02:45 PM
How did you move it?
Have you added an entry in the portalalias table for the site's domain name?
2012-02-08 03:39 PM
hi
first in localhost i add my domain.com as portal alias. then copy all files to host , restore my database and then corrected my connection string.
is it true?!
2012-02-08 03:49 PM
Yes, that is what you should have done.
What is the URL for your home page? What is the URL for the Admin page?
2012-02-08 04:07 PM
hi
in localhost i have http://localhost/senf/خانه.aspx
and http://localhost/senf/Admin/SiteSettings.aspx
and in my host http://domain.com/خانه.aspx
i have http://domain.com/Admin/SiteSettings.aspx
in admin menu just http://domain.com/Admin.aspx work another link like http://domain.com/Admin/SiteSettings.aspx show 404 error :|
in localhost every thing are ok , and when i have clear install on host all things are ok ,
but i have problem when upload my designed site to host
2012-02-12 05:00 AM
What kind of problems do you have with the uploaded site?
Have you changed the portalalias table for the new domain?
Have you configured IIS correctly?
2012-02-12 03:07 PM
hi
yes i do , i solved part of problem , the problem occurred because i set dnn don't use en-us and use only fa-ir ,
now admin menu work but when i clicked on module setting the pop up show 404 error , i disabled pop up but still i have this problem only in admin section modules
other section such as host every thing are true like past!
RE: Deploying dnn by Sameer
Just sent it.
