dnn 4.4 upgrade issue
Last Post 2012-02-07 12:04 PM by Sameer. 2 Replies.
SameerUser is Offline
2012-02-07 07:00 AM
Server Error in '/CooperUpgrade.ma' Application.
Could not find file 'c:\inetpub\wwwroot\CooperUpgrade.ma\DotNetNuke.config'.
Exception Details: System.IO.FileNotFoundException: Could not find file 'c:\inetpub\wwwroot\CooperUpgrade.ma\DotNetNuke.config'.
Source Error:
Stack Trace:
[FileNotFoundException: Could not find file 'c:\inetpub\wwwroot\CooperUpgrade.ma\DotNetNuke.config'.]
System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath) +305
System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy) +1162
System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share) +66
DotNetNuke.HttpModules.RequestFilter.RequestFilterSettings.GetSettings() +149
DotNetNuke.HttpModules.RequestFilter.RequestFilterModule.FilterRequest(Object sender, EventArgs e) +544
System.Web.SyncEventExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() +68
System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously) +75
Version Information: Microsoft .NET Framework Version:2.0.50727.3625; ASP.NET Version:2.0.50727.3618
its so weired issue i am getting
thanks in advanced
2012-02-07 12:03 PM
Thanks you all
it is done by renaming release.config to web.config
2012-02-07 12:04 PM
Thanks you all
it is done by renaming release.config to web.config procedure
RE: Deploying dnn by Sameer
Just sent it.
