Facebook Like Button
Last Post 2012-02-02 12:06 AM by Joseph Craig. 1 Replies.
Jerry EasleyUser is Offline
2012-02-01 04:05 PM
How do I add a Facebook like button to my site? I am using DNN6 and I just don't get it.
Jerry
Joseph CraigUser is Online
2012-02-02 12:06 AM
You can get the code you need from Facebook and then you can paste it into an HTML module in HTML mode. You can also paste it into the header or footer of a module to minimize the chance that the editor will damage the code.
Here are some references:
http://www.dotnetnuke.com/Resources...-Blog.aspx
http://www.youtube.com/watch?v=Pt2AuhYUKck
RE: Deploying dnn by Sameer
Just sent it.
