Object reference not set to an instance of an object - dotnetnuke
Last Post 2010-09-07 01:10 PM by Lee Sykes. 1 Replies.
ranga samyUser is Offline
2010-09-07 11:03 AM
 Hi all,
Thank you for advance.
I have moved web site from one server to another one with same domain name. the site works great on old server.
but I am getting the following error in new server,
Object reference not set to an instance of an object.
Exception Details: System.NullReferenceException: Object reference not set to an instance of an object.
Source Error:
Stack Trace:
[NullReferenceException: Object reference not set to an instance of an object.]
   DotNetNuke.En ies.Portals.PortalSettings.GetSiteSettings(Int32 PortalId) +34
   DotNetNuke.En ies.Portals.PortalSettings.GetSiteSetting(Int32 PortalId, String SettingName) +11
   DotNetNuke.HttpModules.UrlRewriteModule.OnBeginRequest(Object s, EventArgs e) +3549
   System.Web.SyncEventExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() +68
   System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously) +75
How can i fix that error?
2010-09-07 01:10 PM
Things to check:
Have you changed both connection strings in the web.config file to connect to the correct SQL database and server?
Have you reset all permissions on the files and folders for your DNN installation on your new server?
informative!!!
informative!!!
