Script/HTML injection module
Last Post 2010-06-24 03:03 AM by Joseph Craig. 1 Replies.
dkongUser is Offline
2010-06-23 05:41 PM
A client has asked me to embed some Google Spotlight tags. They are meant to go just under the opening tag.
Should I juse a module to do this? Can anybody recommend anything?
Below is a sample tag:
Start of DoubleClick Spotlight Tag: Please do not remove
Activity name of this tag: HOMEPAGE
URL of the webpage where the tag is expected to be placed: http://www.mywebsite.com/Default.aspx
This tag must be placed between the and tags, as close as possible to the opening tag.
Creation Date: 06/23/2010
-->edit: I tried to show a script as I thought it would be displayed in code blocks. Anyway, it's just a standard javascript script with some google stuff in there, and a separate set of comment tags above it.
[script removed]
2010-06-24 03:03 AM
I would recommend Will Strohl's free module. Look for it at willstrohl.com.
