ITextSharp
Last Post 2010-03-15 04:21 PM by Lee Sykes. 6 Replies.
jumattheyUser is Offline
2010-03-09 06:54 AM
Hello all.
I am using IText sharp to generate some random pdf files. I am using this example as a tutorial : http://itextsharp.sourceforge.net/t.../ch01.html
My question is : how do I retrieve the file once I have created it ? Where is it stored.
My question is a bit out of DNN context, but thanks anyway for any info regarding this.
2010-03-09 11:20 AM
I haven't used that, but why don't you do a search on your computer files for the name of the file you saved?
2010-03-09 01:16 PM
It seems that I create the file through the codebehind but it doesn't appear as a regular file on the computer. How do I fix this ? Should the code create the file on the computer ?
2010-03-12 12:54 PM
Problem solved.
2010-03-12 04:17 PM
Glad you got it sorted, what was the solution for anyone else searching for this problem?
2010-03-15 02:38 PM
The key line was this one :
PdfWriter.GetInstance(document, new FileStream(HttpContext.Current.Server.MapPath(@"dir/myFile.pdf"), FileMode.Create));
This line creates the file in the "dir/" repository. Then you can access it thru any regular link.
2010-03-15 04:21 PM
thanks for the info
DNN 6.2 by Sameer
RE: Deploying dnn by Sameer
Thanks a lot so kind of you
I'm confused by this, too.
We are running DNN 6.x
