Where is the logout page in DNN v5.1
Last Post 2009-07-19 02:56 PM by Germaine. 2 Replies.
GermaineUser is Offline
2009-07-10 06:03 AM
Hey all.
May I know where is the logout page located in DNN 5.1? I would like to paste a script to prevent user from clicking after locking out.
2009-07-10 01:19 PM
There is no logout page, per se. There is a logout link that normally appears on every page.
You can set up a page to which the user is redirected after logging out.  That setting is on the User Settings page that you can reach from the Users page.
2009-07-19 02:56 PM
