Friendly URLS's
Last Post 2009-07-02 12:33 PM by Lee Sykes. 3 Replies.
MadzUser is Offline
2009-07-01 11:24 AM
This is the actual Url
Home_enUS/GetaQuote_enUS/tabid/118/language/en-US/Default.aspx
But I need to display in '/auto-insurance-quotes .
Any idea how this could be done????
2009-07-01 10:43 PM
iFinity URL Master module should be able to take care of this, you can setup 301 redirects to navigate to any URL that you desire.
We covered a tutorial on the module here:
iFinity URL Master Module
MadzUser is Offline
2009-07-02 11:44 AM
Thanks Lee..I appreciate your help! What is the inbuilt feature that DNN provides in handling URL..I tried to get the HumanFriendly URL working but still seems some issue
I have added the urlFormat="HumanFriendly" but still I get the URL display in friendly format "http://www.dnncreative.com/Forum/ta...fault.aspx"
I want to get the URL in the HumanFriendly format below--
http://www.dnncreative.com/Forum.aspx
Can you please help y is this not working?
2009-07-02 12:33 PM
this is not something I have experimented with, I have only tried this with iFinity url master
DNN nav issue by imran shaikh
