Pass values from one control page to another ?
Last Post 2010-10-08 07:20 AM by Abhishek Trivedi. 2 Replies.
parag paragUser is Offline
2005-12-22 01:02 PM
I want to pass values from one control  page to another control page without using queystring,or cookies  method.
Take for eg a user name "hash" which i can show it in another page as login name .
I have tried out Context and session methods ...but invain .May be i have got something wrong in my code.
Please if anybody can help me sort out the problem.
2005-12-22 01:27 PM
If you are wanting to grab items such as Username, you can do that easily within the code. But I think you're wanting to pass parameters that someone is entering in a form through to another page?
I had this same problem when i was capturing several pages of data, if I put it in Viewstate the viewstate would be massive, it was way too much data to put into a URL string, cookies - a possibility  etc.. The workaround I did was to store the data directly in the database from each page, but - I did not have to call up previous data on the later pages, so again this may not suit. - The problem with this is it means you are accessing the database several times to add / recall content, which is not good practice.
Have you found any modules that do the task that you require? - I find it useful to refer to the source code of a module that can do the task and then adapt it to suit my needs.
Otherwise, I would try the asp.net forums for advice on best practice.
You may also find further information here:
 http://www.4guysfromrolla.com/
This is an excellent resource for asp.net programming.
I would be interested to hear the solution you implement, so let us know.
Abhishek TrivediUser is Offline
2010-10-08 07:20 AM
Are you looking to pass value from one module to another module? can you please provide more information on this, i have implemented module communication. Pleaes let me know your problem in bit more detail. Thanks,
DNN nav issue by imran shaikh
I successfully installed DNN 6 on my local machine using IIS 7.5. Its working good. When I attach to
RE: Module Security permissions by Bhushan Gholap
Thanks for the reply!!! I would definitely contact sales engineer team of DNN.
RE: There's a tutorial for this somewhere by Eric W
The error I got was the Connection Error(s): Index #: 0 Source: .Net SqlClient Data Provider
RE: DNN 6 Modules Not Showing by Joseph Craig
Where can I see this? If you'd like to send me some login credentials so that I can look, use the c
RE: DNN 6 Modules Not Showing by Mike DeBaise
No, modules are set to all viewers/users. Just cant figure this out, it really doesnt make any sense
