You need to
Register
for free and
Forums
Search Forum
Advanced Search
Topics
Posts
Unanswered
Active Topics
Forums
Users Lounge
Feedback, Suggestions and More
Inbuilt Search Not working
Last Post 11/26/2011 2:19 PM by
. 10 Replies.
Oldest First
Most Recent First
Prev
Next
Author
Messages
Ramesh Narasimhan
11/23/2011 8:43 AM
What kind of text does the in-built search search..I've put text in an html module but it seldome works. How to make the search module work
DNN MVP
11/23/2011 10:13 PM
Go to the Search Results page to configure the Search module. You should also check the Host, Schedule page and make sure that the Search Indexer is running. It you have it set for a long time between runs (which is the recommended setting for productions systems) you may be entering text but not seeing it indexed immediately.
Joe Craig,
Patapsco Research Group
Complete DNN Support
Ramesh Narasimhan
11/24/2011 12:56 AM
everytime i'm getting the following error .
This module is hidden to regular users if there is no Search=xxx querystring parameter.
Ramesh Narasimhan
11/24/2011 1:43 AM
I've placed few text in a new module which i created and trying t search the text within that module.
Ramesh Narasimhan
11/24/2011 2:44 AM
I'v created a new module using .ascx control. When i go to host---------->Extensions and edit the module, I see "IsSearchable" is false and there is no way to make it true. Can i pls know how to make a new module contents searchable.
DNN MVP
11/24/2011 7:29 AM
The "This module is hidden ..." message is not really an error message. This appears on the Search Results page when you go to the page without a search. If you add a querystring Search, you will get a different message if there are no matches.
ISearchable is an interface. Your module must implement ISearchable before items from instances of the module will be placed in the search results. Here is a nice explanation:
http://adefwebserver.com/dotnetnuke...archable/.
Joe Craig,
meard tony
11/25/2011 4:31 AM
content is not rattling an fault content. This appears on the Hunting Results writer when you go to the page without a see. If you add a querystring Activity, you give get a contrary message if there are no matches.
Ramesh Narasimhan
11/25/2011 7:20 AM
How can i implement "Isearchable" interface
DNN MVP
11/25/2011 7:33 AM
Besides the link in my previous message, you can also look at
http://www.dotnetnuke.com/Resources...able.aspx.
The book by Mitchel Sellers on DotNetNuke Module Programming is a great resource.
Joe Craig,
Ramesh Narasimhan
11/25/2011 8:16 AM
My module is a simple .ASCX control and i want to search text placed in this control. Below is the piece of code i've placed
public DotNetNuke.Services.Search.SearchItemInfoCollection GetSearchItems(DotNetNuke.Entities.Modules.ModuleInfo modInfo)
var searchItemCollection = new DotNetNuke.Services.Search.SearchItemInfoCollection();
var searchItem = new DotNetNuke.Services.Search.SearchItemInfo("Apple","Apple", 1, DateTime.Now,10,"Apple", "Apple",10);
searchItemCollection.Add(searchItem);
return searchItemCollection;
I could'nt see any manifest files in the module folders. What should be the module ID field in DotNetNuke.Services.Search.SearchItemInfo. My search for the word "Apple" failed. The run time doesn't seems to be executing "GetSearchItems". Can u pls guide more on this. From where can i get the moduleID.
DNN MVP
11/26/2011 2:19 PM
The ModuleId should be the id of this instance of the module. It is available if your module inherits the correct class.
The iSearchable interface should be implemented in the controller class of the module.
I assume your hard coded "Apple" is just for testing?
Joe Craig,
Special Bonuses
--Subscriber Bonuses
--Readers Offers
Users Lounge
--Announcements
--DNN Creative Articles
--Everything Else
--Membership
--Site Review Please!
--Testimonials
--Podcasts
DotNetNuke®
--DotNetNuke® Questions
--Modules
--Modules - What's needed?
--Quick Tips
Hosting
Skinning Toolkit
--Skinning Toolkit
UK DotNetNuke User Group
Forums
Users Lounge
Can you Run Xcode in Linux?
by Aman Singh
by Aman Singh
by Ryan
by DNN User
by DNN User
by DNN User
by Melanie Weaver
Events Module for DNN V5?
by Tugboat
"Ghost" TabID Number?
by Tugboat
RE: DNN Load Testing
by ayman sharkawy
Publish All Pages
by NSUOK
by Donald
by Donald
RE: Document Collaboration
by Nick Davern
by Donald
by Jakir HM
by peter
