| RE: Background colour by petecarrick |
| Thanks for the reply Joe,The bottom margin seems to be in Firefox only, IE and Safari displays as ex... |
| RE: How to Create Module : by jncraig |
| I'd recommend the book on DotNetNuke module development by Mitchel Sellers, and also adefwebserver.c... |
| RE: Change Login Page by jncraig |
| If you want to add modules to the login page, first create on and add the login module. Then add ot... |
| RE: Background colour by jncraig |
| Use the Web Developers Toolbar to identify the class of the white area. |
| RE: [Server Error]This error can be caused by a virtual directory not being configured as an application in IIS. by arm |
| Posted By mnaoj on 04 Dec 2008 11:46 AMError 1 It is an error to use a section registered as allowDe... |
| How to Create Module : by hassangas2003 |
| this first my question in aforum,i'm abeginer in DNN,I have web user control already used to old pro... |
| Hi,Sorry if this is a real dumb question, I've been experimenting with the Vortex skin and I have ch... |
| RE: Horizontal menu vertical borders by petecarrick |
| That worked perfectly, thanks very much Lee.Pete |
| Change Login Page by edeakin |
| Hey guys it’s me again. Great work on session 46 keep up the great work!
I want to be able to add m... |
| RE: Module Wrapper & Tab Aggregator?? by gbrown |
| Found the Ajax Module Wrapper from Gumbosoft. Bought it and tried it - it works inside of Tab Aggreg... |
| Has anybody tried to place a Module Wrapper module from ZLDNN inside a Tab Aggregator module from DN... |
| RE: SWF Tutorial Conversion by raymueller |
| Thanks and I will continue to research. Each of the applications pick up the introduction (~ 20-25 s... |
| RE: Please do review by leesykes |
| There are a couple of things that you could look at:Initial
page load time of the sites was slow, t... |
| RE: Module Development - Settings Page by leesykes |
| thanks for letting us know the solution and if there's anything else we can help out with please let... |
| RE: SWF Tutorial Conversion by leesykes |
| not sure, its not something I have tried, the swf should convert, perhaps its worth googling around ... |
| RE: not been able to download videos by leesykes |
Normal
0
unctuationKerning/>
false
false
false
oNotPromoteQF/>
| RE: Styling the main menu by leesykes |
| When you add code to your skin.css file, make sure you press CTRL+F5 to reload the page and reload t... |
| RE: Horizontal menu vertical borders by leesykes |
| To find the id of the menu item, use the web developers toolbar for
Firefox, go to information menu... |
| RE: Module Development - Settings Page by HMDevelopment |
| Hello Lee. No thanks -- I have still earned value from this site. I did quite a few 'video' tutor... |
| RE: Can I modify the Default Events module only for a Portal? by jncraig |
| If you create a skin for your site, it will apply only to your site. Also, portal.css applies only ... |
