Subject: GoDaddy
Page 3 of 3 << < 123
ismet dumlupinar
11 Feb 2009 11:44 PM
Hello, i am the owner of that website and although registration is free you must pay a small subscription fee to access certain tutorials.
DNN Tips
DotNetNuke Help for beginners
mark.m.moran
12 Feb 2009 4:34 AM
Hi guys,
I'm currently at College and have no form of income so I am unable to currently pay the subscription fee. I would really love to get my first DNN site up and running. Are there tutorials available anywhere else? Thank you for all your help so far.
All the best,
Mark
ismet dumlupinar
12 Feb 2009 8:37 AM
Contact me Mark (using Contact form at my website) and tell me your username i will assign your user account to subscribers role so that you can view the tutorial.
For those non-profit users, i will giveaway free access.
Thats all i can do for now.
Thanks.
DNN Tips
mark.m.moran
12 Feb 2009 12:00 PM
Hey greenflash,
You are very very kind. I will contact you at your website now.
Cheers,
Mark
12 Feb 2009 12:30 PM
It's back now ...
mark.m.moran
13 Feb 2009 2:09 AM
Hey greenflash,
I sent you a message through the contact form on your website about getting my account upgraded, did you get it?
Cheers,
Mark
ismet dumlupinar
14 Feb 2009 4:02 AM
@mark.m.moran
I haven't received any message from you yet, but i was able to find your username through site reports and i just upgraded your user account to have access to tutorials.
Please let me know if you need more help.
Regards.
DNN Tips
mark.m.moran
14 Feb 2009 11:41 AM
Hi Greenflash,
Thank you very very much for that. I will let you know how I get on.
All the best,
Mark
mark.m.moran
15 Feb 2009 10:31 AM
Hey guys,
Thanx to the tutorials from Greenflash and this website http://spencerteck.com/cms-guides/1-dnn/2-godaddy-root-install-part-1 I am happy to say I got DNN 4.9.1 installed on GoDaddy. I am using the economy option and it worked fine.
As soon as I got it setup I logged on as the admin account to reset the password and was able to reset it no problem. I then logged in as host and wanted to also reset the password for the host account too in order to secure my site.
The problem is each time I try to reset the password or create a new acocunt I keep getting the follwing error.
"s.WebForms.PageRequestManagerParserErrorException: The message received from the server could not be parsed. Common causes for this error are when the response is modified by calls to Response.Write(), response filters, HttpModules, or server trace is enabled.
Details: Error parsing near 'alid/0/Default.aspx¦
I have tried to change a number of things like the website name etc. etc and keep getting the same error.
Would anyone know why this is? Have you seen this before?
Cheers,
Mark
ismet dumlupinar
15 Feb 2009 11:08 AM
Probably because of Economy Plan limitations you received this error.
In my tutorials, i have focused on Deluxe Plan, i think you will also have issues with Container Menu Action buttons since they are using AJAX.
DNN Tips
mark.m.moran
15 Feb 2009 11:56 AM
OK, I will play around with it some more and see how I get on......
mark.m.moran
15 Feb 2009 12:11 PM
In your tutorial you mentioned that a friend of yours had used the economy plan without any issues. Were they able to install OK and then had problems after?
Folder permissions by saintX
That will work.
