Subject: SMTP Setting error
zooomit
15 Mar 2008 1:26 AM
Hi all! can anyone tell me why this error comes and what is the solutions I am trying to set the smtp server setting for mail setup bt it shows this error please port: Enter the SMTP Server Address. You can also specify an alternate port by adding a colon and the port number (e.g. smtp.googlemail.com:587). Enter the SMTP server name only to use default port number (25) Test There has been an error trying to send the test email. The error is: Mailbox unavailable. The server response was: (COMP6) 𖏲.162.11.198] is currently not permitted to relay through this
15 Mar 2008 9:29 AM
Your SMTP server is refusing to send the mail because it thinks you are "relaying" mail through it. This is a technique that's designed to stop spammers from using an SMTP server.
You will need to have the person who manages the SMTP server to permit your DotNetNuke installtion to use it.
sondlerd
19 May 2008 3:03 PM
Any further instruction on how to enable the smtp server for DNN?
thanks in advance
19 May 2008 3:13 PM
What kind of additional help do you need? The settings that you need should be available from your hosting provider.
19 May 2008 6:52 PM
And be sure to look at How to set up email in DotNetNuke
sondlerd
20 May 2008 7:10 AM
I got it to work. I am actually using Windows 2003 Server. I had to set the address of the Host email as well as the SMTP server to use the fully qualified domain name of the Win 03 server on the domain.
thanks
Hello,DNN Nav is available with the default install of DotNetNuke and already installed. - Just look...
RE: Congratulations to Lee and the DNN community! by leesykes
Hello,Glad to hear it is useful. I didn't go for the DVD, but went for the net effect magazine, rece...
RE: Register and Login Links by jncraig
The general scheme is that CSS styles are attached to skins.  I believe that it's possible to switc...
RE: User Import from Excel by jncraig
I have used John Mitchell's script (http://blogs.snapsis.com/PermaLink,guid,c9d3082b-d7b1-4dfb-8c9c-...
User Import from Excel by sstoos
I'm working on a website that the client has several 100 members that they want to add as users.  Is...
RE: Menu bar and CSS by wsiwpg
Ok, i have now added some sub pages to the site. Can you please go look at it now.Thanks.
RE: DNN Creative News Feed not Working? by mgordon
In my humble opinion, the latest News Feed Module (version 4.00) is a complete piece of crap.  It ha...
RE: Register and Login Links by Faith
Joe: Two short questions. 1) It is possible to set a css style sheet for a determined user? ...
Hello, Below is a few paragraphs outlining some background, but my question is: Can I take a p...
RE: DNN Creative News Feed not Working? by ollep
  One last bit before bedtime.   With the below section in the “.xsl” I managed to get it down to...
RE: DotNetNuke UK User Group Meeting by leesykes
This meeting is now cancelled due to insufficient numbers, we will try again in the new year
  Hi Again.   Seems like the “News Feed Style Sheet” option is changed to “XSL Transformation? A...
Hi Again.   Now I’m on to the News Feed Module and RSS Feed.   Is the News Feeds 04.00.00 quite ...
RE: Query regarding menu by jncraig
Doing that forces a reload and recompile of your site.
RE: Query regarding menu by ImageSmith
I have had this problem before. A quick fix: retouch the web.config file by opening in notepad, make...
RE: Trying Flash again - in Firefox. by jncraig
Here is how we have done it ... Note that I put in a bunch of spaces to break the tags, so you'll ...
RE: Changing the House Menu?? by ollep
Thanks lee. The configuration for the separate sub-menu-item list, do you show that in a tutorial...
Trying Flash again - in Firefox. by ollep
I still looking for ways of running Flash Movies in Firefox??? The code provided in the DNN Creat...
Thanks Joe! Just tested and it works fine.   Only thing was that I could only save in the portal ...
Congratulations to Lee and the DNN community! by ollep
On Lee’s recommendation I ordered the “Stompernet DVD” and the first issue of “Net Effect” – and che...
