Subject: Re-invent Technologies
reinventme
26 Sep 2005 9:10 PM
http://www.re-invent.com/dotnetnuke.aspx
Re-invent DotNetNuke® Hosting Features
  • Windows 2003 Server Hosting Platform - Reliable and Stable
  • Free Installation of DotNetNuke® on any hosting plan starting as low as $7.16 per month
  • Managed Backup / Recovery of your data - Re-invent backs up all data daily and is available for recovery at anytime at your request.  Make a mistake with your site is not a problem as we will restore your data from the last back-up within 1 hour at no charge.
  • High Reliability / Expert Support / Less Headaches
reinventme
03 Apr 2006 8:02 PM
Updated Info for Re-invent (http://www.re-invent.com):
- Free Installation of DotNetNuke 3.1, 3.2 or 4.0 by Re-invent
- Use Custom and Commercial Modules
- Custom and Commercial Skin Compatibility
- Multiple DotNetNuke - DNN Portals
- Member of the DotNetNuke Gold Benefactor Program
- ASP.NET Hosting with ASP.NET 2.0 Hosting
youngboy
29 Apr 2006 10:57 AM
I currently have 3 DNN sites running on these guy's servers along with numerous other standard sites and find there response to questions very accurate and fiar. Highly recommend!
Just a client.
Forums > Hosting > DotNetNuke® Hosting Providers > Re-invent Technologies
RE: Cannot view host filespace using text/html editor by NonStopMark
Hi Joe, The problem has gone away. May have been a caching issue. Thanks for posting. DNN : ht...
Firefox Does Not Display WMV File In Media Module by johnmk777
Hi All,I can't believe I am having such a hard time finding and answer to this question.  I have see...
