Subject: JodoHost
26 Aug 2005 12:51 PM
http://www.jodohost.com/
Shared Windows Plans
(they also have Reseller Hosting, Semi-Dedicated, and Managed Servers.)
Value Silver Gold Platinum Titanium
Setup Fee $0.00 $0.00 $0.00 $0.00 $0.00
Monthly Fee $6.95 $12.95 $18.95 $24.95 $30.95
Service
24x7 Customer Support Yes Yes Yes Yes Yes
Dual Xeon 2.4GHZ servers Yes Yes Yes Yes Yes
Multi-Homed Network Yes Yes Yes Yes Yes
Daily Server Backups Yes Yes Yes Yes Yes
99.5% Uptime SLA Guarantee Yes Yes Yes Yes Yes
Money Back Guarantee Yes Yes Yes Yes Yes
Resources
Disk Space 400MB 800MB 1200MB 1600MB 2000MB
Monthly Transfer 10GB 20GB 30GB 40GB 50GB
Domains 3 6 9 12 15
Sub Domains 10 20 30 40 50
Domain Aliases Unlimited Unlimited Unlimited Unlimited Unlimited
Dedicated IPs 1 Free 2 Free 3 Free 4 Free 5 Free
Databases
Oracle 10g TableSpace * N/A 50MB 75MB 100MB 125MB
Oracle Users N/A 2 4 6 8
Microsoft Access Unlimited Unlimited Unlimited Unlimited Unlimited
Microsoft SQL Server 2000 1 Database 2 Databases 3 Databases 4 Databases 5 Databases
MySQL 1 Database 2 Databases 3 Databases 4 Databases 5 Databases
PostgreSQL 1 Database 2 Databases 3 Databases 4 Databases 5 Databases
DSN/ODBC Unlimited Unlimited Unlimited Unlimited Unlimited
SQL Database Users Unlimited Unlimited Unlimited Unlimited Unlimited
Enterprise Manager Access Yes Yes Yes Yes Yes
phpMyAdmin Yes Yes Yes Yes Yes
phpPGAdmin Yes Yes Yes Yes Yes
WpgBri
13 Nov 2005 6:18 PM
My first install using DNN 3.1.1 hasn't worked, at least not fully. They were helpful runnubg the scripts, etc, but the email component doesn't work. Something in aspnet_Membership. The initial install created a bunch of DB_User owned tables and SPs. So some of the calls are wrong.
They are helpful in recovering the DB, renamind all owners to dbo (that caused the whole site to fail), etc. But definitely are not DNN savvy.
If I can get them over that hurdle, I will definitely recommend them. No phone support, but everything else is good to very good.
WpgBri
18 Nov 2005 10:03 PM
The first problem was mine. My developer friend suggested I use my DB User as owner in the web.config in the end data section. This caused the problems noted above.
I'm following JodoHost's install procedure and the DNN Install Guide, and it has come up fine.
I haven't got the Newsletter section fully working yet. I can add a List, and that works. I've put in some test Users, and selected Registered Users, but the emails only go to my admin address.
WpgBri
30 Nov 2005 12:01 PM
Got it all sorted out. For some reason, putting the mail server address in the Host Settings causes the system to do funny things. Leave it blank and all works fine.
JodoHost service is good, although performance with DNN is not the fastest. Still better than many. Their email support is decent. For DNN, I'd recommend ResllerChoice first. I do prefer JodoHost's process of adding email accounts, but how often do you do that?
eureka
12 Dec 2005 7:42 PM
I have found that JodoHost in general offers a good value for money service. But as this is my first DNN site I have nothing to compare it with. The support they offer is good.
eureka
30 Jul 2006 8:38 AM
Hello
I had a few major problems with my site some time ago exactly who's fault it was I am not 100% certain.
However, I have found that the support given by Jodohost is excellent, they go out of their way to help. Although I have to say I have found that I must be very specific with questions or requests, as the language difference occassionally means that not everything is understood as intended. Consequenlty things get a bit confused which could lead to unnecessary problems.
 I have appreciate all the help that they have given, which has been a lot.
Regards
Lynn
eureka
18 May 2007 6:17 AM
Hello
Jodohost support and customer service is excellent. It is a pity that their servers (Resellers Shared Hosting Package) are not.  But you cannot expect supperior server services, for bargain basement prices.
RE: Server Application Unavailable from localhost by picoallen
OK, I've got things working better now. Not sure why though as I lost track while following all the ...
e-Survey? by mgordon
I need a module that will do the following:When a person comes to a specific page (recreation guide ...
