Subject: Add new portal -new portal administrator login unable to access admin menu
Hari
04 Dec 2009 5:26 AM
I have a portal named portal#1 in DNN. I have added a new portal called portal#2. While creating portal#2 i added a new admin called admin#2.
However when i login with Portal#2 with admin#2 credentials i am unable to access the admin menu. I logged off portal#2 and logged in once again with superuser (host) account. Now i was able to access Host menu.But i am still unable to get access to admin menu. I need the admin menu to change some site setting & page settings
Any suggestions on how to overcome this? Thanks in advance
Hari
04 Dec 2009 5:29 AM
Just to add to what is written above - admin#2 was created while creating portal#2.(While creating a new portal we are prompted to add a admin)
04 Dec 2009 8:59 AM
Which version of DotNetNuke?
Does Portal #1 work just fine?
Hari
04 Dec 2009 1:00 PM
Portal#1 works fine. The admin and host logins work well. The issue ijavascript:WebForm_DoPostBackWithOptions(new WebForm_PostBackOptions("dnn$ctr419$NTForums$AF_TopicView$amQuickReply$lnkPost", "", true, "", "", false, true))s with portal#2. We are using DNN 5.1.4
04 Dec 2009 7:26 PM
You might want to try upgrading to 5.2.
Hari
09 Mar 2010 6:38 AM
I am re-opining this topic. Will  this issue will be resolved if i upgrade to 5.2 ? Is there no fix for this in DNN 5.1.4. The weird thing is that even the 'host' login cannot access the admin menu. Whenever an admin menu item is clicked it gets redireceted to the home page. Is there something that can be done at the database level to get this resolved. Migration to 5.2 would be the last option for me
Thanks in advance
Forums > Hosting > DotNetNuke® Hosting Providers > Add new portal -new portal administrator login unable to access admin menu
How to do links? by Guy..L
How to close a website while you are working on it by mcmanta
The LOGIN and REGISTER links are Skin Objects that are included in your skin file. The easiest way ...
I would like to remove the 'LOGIN' text from the top right of my pages.   How can I do this?   I tri...
Yes, that is the one.
Thanks for the tip. I will let my programmer check it out. This is the module you're referring t...
RE: extending user accounts for membership by jncraig
Try these:User Accounts new features User Accounts and User Settings Enforcing Terms and Conditions ...
RE: DataSprings Dynamic Forms Demo #20 Question by jncraig
There are some nice examples on the Data Springs site.  The more complicated demos do require some s...
RE: Dynamic Forms Email From User/Pass by jncraig
If the SMTP server is configured so that it will not send email from arbitrary email addresses, I wo...
Glad that you got it solved.There is a free module available from Iowa Computer Gurus that automates...
