Subject: Hosting a dnn site on a port other than port 80
Hari
30 Nov 2009 5:44 AM
I am having issues in hosting a dnn site other than port 80. I am trying to host 2 seperate DNN sites on the IIS server. I have disabled the default web site in IIS
I have configured one site to port 80 (SITE#1)
I have now configured another site to port 8080(SITE#2)
I have modifed web.config file of SITE#2 and added the following under appsettings . However whenever i try to access SITE#2 i am taken to SITE#1.
Is there some additional settings i need to do on either SITE#1 or SITE#2?
Rashid Kazi
02 Dec 2009 6:33 PM
Do you have a specific need to run second DNN on Port 8080? Because HTTP Port 80 can handle both websites, even more.
Which version of IIS do you have? do you have DNN installed on local machine?
Rashid Kazi
DNN4Less - Support Department
FREE DotNetNuke Hosting for beginners.
888.523.2360
www.DNN4Less.COM
Hari
03 Dec 2009 2:52 AM
We are using IIS 6.0 . Can you please let me know configuration steps to host a dnn site on a port other than port 80. We will eventually have one DNN installtion with multiple sites
04 Dec 2009 9:03 AM
From a post at DotNetNuke.com:
You'll need to include the element < add key="UsePortNumber" value="True" / > in the < appSettings > node of your web.config file.  This flag will enable the port-parsing code in the urlRewrite httpmodule.
Your final httpalias will look something like:
localhost:30000
You will also need to make sure that the port number is included in the portalalias table.
Forums > Hosting > DotNetNuke® Hosting Providers > Hosting a dnn site on a port other than port 80
RE: OWS Query Template Results by VickySwift
Hi, In the end I achieved what I needed with IIF statments and ALTERNATE Pretty sure its not the...
RE: Login problem with other browsers than IE by kana
I added alert(); into onkeypress and now after I press enter on messagebox page is forwarding fine. ...
RE: OWS Query Template Results by kana
I don't know, that is possible, but I would try to use javascript in dteial template to build string...
RE: How to change primary domain? by aventhika
Hi it is an easy ,for that change visit here ,i am using this site only for my change.All the Best...
RE: Link to PayPal Unsuccessful by jorge569
Same problem here....please post answer
daisy chain continuous loop of all the flash files by mlorence
I have an install of dnn 05.02.02. I had a flash guy make a movie for my home page. There are 6 file...
Furniture Store Web 2.0 DNN Skin by coding-staff
Coding Staff is proud to announce a release of DNN Skins and Furniture Store Web 2.0 DNN Skin Ne...
301 Redirect on GoDaddy by kayt61
Hello,I have been looking for a simple set of instructions on how to make a 301 redirect from www.my...
Hello, I have three pages in DNN - Login, Main and Advanced. Login contains only OWS module for ...
RE: Request a Tutorial:Forms and SQL by leesykes
That's great, thanks for adding this in Dave
RE: Request a Tutorial:Forms and SQL by dhassall
I have added a new forum entry which I hope will help others http://www.dnncreative.com/Forum/tab...
DataSprings DynamicForms Form Completion Dynamic SQL by dhassall
I trawled around trying to find out why my SQL Insert was not working. After some trial and error...
RE: HTML module not updating after transfer from localhost to live server by chrisoc
Hey guys,Thanks for the replies.   All seems to be working fine now.  I had previously cleared the b...
RE: w2k8 r2 - dnn site visible locally but not from internet by guyperrin
thanx joe. i just kept slugging away at this one. finally, when i gave IIS_IUSRS Full Control, i w...
RE: HTML module not updating after transfer from localhost to live server by jncraig
Check to make sure that you adjusted your portalalias table to point to the live site. It's possibl...
RE: w2k8 r2 - dnn site visible locally but not from internet by jncraig
Check to make sure that DNS points the site's URL to the web directory.  Your host ought to be able ...
RE: user retrieve password by giving email by jncraig
That should work. As with most things like this, I would recommend that you test and verify this ...
RE: Creating a new user by jncraig
DotNetNuke uses the ASP.NET membership scheme. I haven't tested, but I am reasonably surethat the s...
RE: Email Verification by jncraig
Is this a question about Dynamic Forms? You can use Regular Expression validation to force the us...
RE: Issue 33 SQL updating page settings by jncraig
Can you describe the problem a bit more?
DNN Creative Subscribe
