Subject: HAPPY THANKSGIVING from DNN4Less - The Great SALE Starts Black Friday, 11.27.2009
Kevin Bowers
26 Nov 2009 12:33 AM
Untitled Document
HAPPY THANKSGIVING TO ALL.
WISHING ALL OF DotNetNuke COMMUNITY MEMBERS A SAFE AND FUN HOLIDAY SEASON.
WE HAVE BUILT A FEW GIFT PACKS AND SALE ITEMS FOR THE HOLIDAYS. SO MAKE LIKE A TURKEY AND GOBBLE UP THESE SALES AND SPECIALS BEFORE THEY ARE GONE!
WWW.DNN4LESS.COM
HAPPY HOLIDAYS FROM THE DNN4LESS.COM'S STAFF.
DNN4Less.COM
DNN. It's in our DNA
888.523.2360
Forums > Hosting > DotNetNuke® Hosting Providers > HAPPY THANKSGIVING from DNN4Less - The Great SALE Starts Black Friday, 11.27.2009
RE: Permissions Question by BCRose
Does that involve editing the source code? May not be too big of a challenge to you but that is som...
Is this fixed now?
RE: Permissions Question by jncraig
Well, thinking about it ... it would not be too big of a challenge to take the module, remove the fe...
Ummm...too bad. That seems like a no-brainer for this module.
I don't believe that's possible. I'd love to learn that I'm wrong.
Ok, Thanks for the info. I was able to make those changes, Now...I want this user to be able to ad...
In DotNetNuke 5.x, you have control of permissions on the Admin and Host pages. So, you can grant p...
Is it possible to give a user permission to add and delete users, change pw's etc. without giving th...
RE: daisy chain continuous loop of all the flash files by mlorence
I made a test html page in Dreamweaver and it works perfectly, just as it does on my desktop. I u...
Sorry about that. That was my test domain and I just switched it to the permanent....http://www.neb...
Strange behaviour when pressing login by pontus66
Hi,When pressing Login (Sign In) on one of my clients portals the adress for the homepage gets sort ...
RE: My site is down by proarch123
Thank you Lee Sykes
RE: daisy chain continuous loop of all the flash files by jncraig
I would imagine that each file includes a URL to other link to the next file. That works fine on yo...
RE: Install Skin Error Message by jncraig
Where did you get this skin? It seems to be missing a file, license.txt, that is a required element...
RE: domain name by aventhika123
Hi, for expected Domain name use this http://www.xnynz.com/ site ,here only i got my all sites doma...
RE: How to Create a Custom Login Module with OWS - Issue 52 by kana
I modified Your example with one thing - looking for enter key on password field. I added that in Re...
Install Skin Error Message by Captain Canary
Hi When trying to install a new skin via Extensions with DNN v 5.2.3 I get the following error m...
RE: OWS Query Template Results by VickySwift
Hi, In the end I achieved what I needed with IIF statments and ALTERNATE Pretty sure its not the...
RE: Login problem with other browsers than IE by kana
I added alert(); into onkeypress and now after I press enter on messagebox page is forwarding fine. ...
RE: OWS Query Template Results by kana
I don't know, that is possible, but I would try to use javascript in dteial template to build string...
