Subject: Frankland Hosting
26 Aug 2005 12:48 PM
www.franklandhosting.com
Each DotNetNuke Hosting Plan includes:
  • Free DotNetNuke installation
  • 11 free modules installed including: a Blog, Gallery, and Forums
  • 13 free skins installed to give your portal a unique look
  • Unlimited Domains, Sub Domains, and Domain Aliases
  • Microsoft SQL Server and Access databases limited only by disk space
  • Unlimited Mailboxes / Forwards / Auto-Responders / Mailing Lists
  • H-Sphere Control Panel
  • FrontPage 2002 Extensions
  • Custom Error Pages
  • Server Log Access and Web Based Statistics
  • No Setup Fee
DotNetNuke Personal
$3.95 per month
5GB Transfer
150MB Disk Space
Non-Commercial
Additional Options
Additional transfer : $2.00 / GB
Additional disk space : $0.10 / MB
Static IP : $2.00
Service Level Agreement : 99% Uptime Guaranteed
ASP.NET Applications Installed Free
DotNetNuke Value
$8.95 per month
5GB Transfer
150MB Disk Space
100% Uptime
Additional Options
Additional disk space : $0.08 / MB
Static IP : $2.00
Service Level Agreement : 100% Uptime Guaranteed
DotNetNuke Bronze
$14.95 per month
9GB Transfer
300MB Disk Space
100% Uptime
Additional Options
Additional transfer : $1.80 / GB
Additional disk space : $0.07 / MB
Static IP : $2.00
DotNetNuke Silver
$19.95 per month
15GB Transfer
500MB Disk Space
100% Uptime
Additional Options
Additional transfer : $1.50 / GB
Additional disk space : $0.06 / MB
Static IP : $2.00
DotNetNuke Gold
$29.95 per month
32GB Transfer
1000MB Disk Space
100% Uptime
Additional Options
Additional transfer : $1.10 / GB
Additional disk space : $0.05 / MB
Static IP : $2.00
DotNetNuke Platinum
$39.95 per month
64GB Transfer
2000MB Disk Space
100% Uptime
Additional Options
Additional transfer : $0.80 / GB
Additional disk space : $0.04 / MB
Static IP : $2.00
DotNetNuke Corporate
$99.95 per month
160GB Transfer
5000MB Disk Space
100% Uptime
Additional Options
Static IP : $2.00
