Subject: PowerDNN
Joseph Brewster
29 Oct 2009 3:08 PM
PowerDNN has been a breath of fresh air in a world of lackluster DNN
hosting. I never realized how simple and efficient DNN hosting could be
until I gave them a try. After laboring through a torturous install process,
downtimes, and tech support who were less than knowledgeable of DNN on my
previous host, I was delighted to encounter a helpful, prompt, and well
trained staff at PowerDNN who walked me through adjusting to a different
control panel, and personally made sure my site was live and working. I have
been using DNN for almost 4 years, and I am wishing I had made this switch
sooner. My encounters so far have led me to believe that I am dealing with a
team who know what they are doing, and have a commitment to customer
support. I highly recommend PowerDNN based on my experience, and I would
challenge anyone to find a better hosting service for DNN-I certainly have
not.
Joseph Brewster,
Graphic Design Director
www.embryoconceptdesigns.com
P.S. It's always a challenge finding your way around a new hosting providers control panel and menu, but the support has been very helpful. I have been bugging them non-stop and they have consistently provided helpful info and walked me through the transition. It's really nice to be able to contact LIVE people within 2-3 minutes who can answer my questions. I have done the DNN on Godaddy gauntlet, got it working, and kept it running, I have also worked with several other high end hosting services, but none who were more attentive and knowledgeable about their stuff. Just my 2 cents! ;)
That will work.
