Subject: Limited Time Only: Power 1 Economy Dedicated Server - $180/mo
Mr. MobileNow
15 Oct 2009 10:12 AM
 Hi Everybody,
I wanted to let you know that right now we have our Power 1 Economy dedicated servers available.  This is a heavily discounted promotion that we only offer twice a year, so if you were thinking about getting a server, there is no better time than now.
The Power 1 Economy is an entry level dedicated server specifically designed for small organizations who are just starting out and have 10 DotNetNuke websites or less.
The Power1 Economy is an all-inclusive dedicated server that contains everything you need, such as:
SQL Server 2008
EMail Server
DNS Server
FTP Server
Plesk Control Panel
and the PowerDNN Control Suite
Supplies are limited so when we're out, we're out!
-Tony Valenti
DotNetNuke DNN Hosting
kemper burt
15 Oct 2009 10:23 AM
Hi Tony is this still available, I've been a long time customer although scale of economy is forcing me to look at my options. Thanks Kemper
Forums > Hosting > DotNetNuke® Hosting Providers > Limited Time Only: Power 1 Economy Dedicated Server - $180/mo
That will work.
