Subject: FRE DOTNETNUKE HOSTING FOR BEGINNERS.
Thomas McGill
02 Aug 2009 3:36 PM
I am new to dotnetnuke, as well as in this forum, and was looking for inexpensive hosting to learn,  my good luck, dnn4less is offering six months free hosting for beginners.
six months are enough to learn dotnetnuke? any advise to a beginner please.
05 Aug 2009 4:06 AM
yes the six months should be plenty of time to learn DotNetNuke. If you view the video tutorials on DNN creative you may find you are up and running in a matter of hours.
Forums > Hosting > DotNetNuke® Hosting Providers > FRE DOTNETNUKE HOSTING FOR BEGINNERS.
Glad it's working!
Firefox SWF file by ce221
PayFlow Link by murphydolores
RE: Send email with Dynamic Forms Results by jesp17
Hi Lee,I've asked DataSprings if there is a way to solve my problem (wish). Here is a reaction:I don...
