Subject: My-ASP.Net Hosting
Ken
05 Mar 2009 7:35 PM
DotNetNuke Hosting
My-ASP.Net's DotNetNuke Hosting solution provides one stop shopping for everything you need to build high performance DotNetNuke websites starting from $8.99 CAD, includes: high speed hosting, easy to use DotNetNuke install wizard, step by step instructions to customize your DNN websites look and feel plus 'how to tutorials' that enable you to create advanced DotNetNuke web pages, use SSL and configure site security policies, personalize website content, send newsletters, and more
Supported ASP.Net Hosting Platforms
Free DotNetNuke Help Desk
DotNetNuke 101: User Guides and Documentation upgraded for DNN 4.9.2
  • 30+ new DotNetNuke Tutorials with screen shots
  • DotNetNuke Skin &Web Design Recommendations
  • DotNetNuke Search Engine Optimization Instructions and Suggestions
  • Access requires a valid My-ASP.Net hosting account.
DotNetNuke Help for Hire
DotNetNuke Support: Single Incident tickets, Pre packed SLA’s, Custom Service Level Agreements
Spring Hosting Specials  (Expire Date: April 15, 2009)
Free Fully Customizeable DotNetNuke Skin & Container set, ($49.00 value) with 6 any month hosting term
10% Off custom DotNetNuke Skins & Containers
Save 25% when you purchase any DotNetNuke Bundle:
At My-ASP.Net we believe in building better customer relationships . . .
That will work.
