Subject: IntCom
Sharman
13 Aug 2006 6:54 AM
IntCom (Pty) Ltd. offer both shared DNN hosting and exclusive use DNN hosting.
Shared hosting offers: -
Parent Portal at R100.00 pm
Child Portal at R80.00 pm
Both options include an eMail account and 100MB free bandwidth per month
Exclusive use DNN Hosting
Includes eMail account and 100MB free bandwidth
Visit us at http://www.intcom.co.za and http://www.dnnportals.co.za
