Subject: Best way to put images in navigation menu
fmeyer
29 Mar 2008 1:18 PM
What is the best way to put images in my primary navigation menu?
My client wants each menu item to look like a differently shaped opaque leaf with the menu text sitting on top of that leaf (sounds odd, but it looks pretty cool).
SolPart Menu does not seem to support this functionality. Does another module exist that supports this "out of the box". If not, is there one (like HouseMenu?) that comes close?
eureka
29 Mar 2008 1:59 PM
Hello fmeyer
You might like to look at Snapsis CSS NavMenu it is very flexible, link below:
http://www.snapsis.com/tabid/589/ProductID/13/List/1/DotNetNuke-CSS-SEO-Menu.aspx
Lynn
02 Apr 2008 9:00 AM
ps. if you are a subscriber, there is a 35% discount available from here:
http://www.dnncreative.com/Forum/tabid/88/view/topics/forumid/17/Default.aspx
andyb1979
09 Apr 2008 9:07 AM
I found that subscriber code to not work when I tried it a couple of months ago
Rock Rhyme & Reason Fest | The Big Match | Calvary Stockport | Stephen Webster
09 Apr 2008 7:34 PM
Did you check with either Lee or John Mitchell?
10 Apr 2008 3:07 AM
Make sure the capitalization of the coupon is correct.
The discount now just applies to the single use version rather than the developers version
Forums > DotNetNuke® > Modules - What's needed? > Best way to put images in navigation menu
