Subject: Help for including time() in php.
marlonbrando
28 Mar 2008 4:08 PM
I am new to php and i am working at a project .The modules here need a inclusion for the php time function (),which i think is a most  important part of php time values and functions.while  applying the function(),i encountered a problem that my module couldn't access the server time.
kindly post me some help regarding this.
regards,
Marlon.
31 Mar 2008 8:52 PM
DNNCreative supports DotNetNuke. We really don't support php.
Forums > DotNetNuke® > Modules - What's needed? > Help for including time() in php.
