Subject: loging setting (very importent)
rizwan7705
10 Mar 2008 7:09 PM
can some one help on this please
i m trying to do if users r registering themself  all the information shud be displayed in the other page(new page) automaticly what they put in the registration page. and other people shud be able to search that page and look at it. but shudnt be able to change it
 please help me out lee that ll be great help. i m new to dnn.
 please tell me what moduel do i need thanks
r javed
14 Mar 2008 6:42 AM
I would have a look at some of the modules available on http://www.smart-thinker.com/
If you look at the right column on their home page you can see a module which appears to cover your needs.
Forums > DotNetNuke® > Modules - What's needed? > loging setting (very importent)
